electrical problems
Old Oct 3, 2009 | 09:50 AM
scott lingle's Avatar
Question electrical problems
my headlights will not work then i shut the ignition off and restart and they work most of the time and its usually just one and they take turns also my keyless entry stop working the doors but still works the hatch and sunroof.can anyone help with info on this
Old Oct 6, 2009 | 08:04 PM
bad relay on the headlights, keyless check fusing do you get the lights flash ??? just not opening
Old Oct 12, 2009 | 11:21 PM
benbartell's Avatar
Default Lights flash on mine but don't unlock
Hey guys! My keyless entry doesn't work either. It will lock the doors, but not unlock. It started with the driver's side door which wouldn't work, but the passenger side worked. Now neither of them work. Help! I have a 7 month old baby and getting her into the car without the keyless entry SUCKS!
Old Oct 20, 2014 | 07:01 PM
GreenHornet03's Avatar
checked the fuse and replaced the battery but still not working anything
Old Oct 30, 2014 | 10:02 AM
Check the main battery for low voltage, then your keys have a built in battery. Swap keys if you have the other one, from the factory MINI came with two keys. If you have comfort access ( little black rubber button on the door handle ) you will have the extra battery ( replaceable ) in the keyfob which is for opening the door when locked and starting the car with the key in your pocket.
Pam
Jun 29, 2011 08:19 PM
leftzilla
Oct 20, 2009 09:53 PM
joesmithf1
Oct 12, 2009 09:41 AM
hmccarthy526
Aug 22, 2008 08:43 PM
clowncar04
Mar 5, 2008 08:05 PM
