shifting noise
Old Nov 15, 2009 | 10:21 PM
04minis's Avatar
Default shifting noise
Hi All,
I picked up an 04 Mini Cooper S 6-speed on Nov. 5th in very good condition. I'm still getting used to it, as it is very different from my last car.(Nissan Altima)
I have noticed I can hear linkage noise and clutch release and engagement sounds while shifting. Not overly loud, but concerning as I do not hear these sounds while driving my wife's VW beetle.
Is this normal?
Thanks for any feedback
Old Nov 16, 2009 | 04:44 PM
04minis's Avatar
Also, when the car is idling, there is a knocking noise, but stops when I push the clutch in.
Is my clutch on the way out, or just needs adjustment?
Old Nov 21, 2009 | 01:49 PM
How many miles ???
Confused , knocking noise when in idle ?? Car in Neutral ??? Sound goes away when clutch in ???
Old Nov 22, 2009 | 05:58 PM
04minis's Avatar
90,000 km (56,000 miles)
Yes, knocking noise when idling in neutral, clutch out. Stops when clutch depressed.
Are Mini's supposed to be kind of hard shifting and noisy? Not buttery smooth?
Old Nov 22, 2009 | 08:13 PM
no they are pretty smooth and easy to shift ...
has this had a short shifter installed ???
Old Dec 16, 2009 | 04:37 PM
Erik Johnson's Avatar
Default I have a possibility
Hey there,
I realize that I am new here but we specialize in gearboxes here. What you have what sounds to me like a throw out bearing going bad, or possibly a bearing internal to the gearbox that is failing. You may wish to check in with BMW, as I know they have seen this problem come up quite a bit.
Hope that this helps,
Erik Johnson
GBox Performance Transaxles
(303) 440-8899 work
(303) 895-4828 cell
Old Dec 18, 2009 | 06:53 PM
04minis's Avatar
Default Not getting any worse
Thanks for your reply Erik,
I have driven the car almost 5000km now and the noises don't seem to be getting any worse. In fact sometimes the knocking noise isn't even there. Function doesn't seem to be impeded although I've not driven another Cooper S to compare.
I do think I'll take it to BMW before my extended warranty runs out though, and have them assess it.
Old Dec 21, 2009 | 03:32 AM
  #8
DekFepfiefs's Avatar
Banned
my fan got worse, i had a replacement fan sent to me for free, and replaced it myself, the noise is gone.now... any suggestions on tp fan control utility thresholds and settings? to prolong fan life? next year if/when this happens, i wont be under warranty, and will have to purchase the fan.thanks
surferian
Jul 14, 2018 01:20 PM
MINIman1187
Dec 11, 2011 01:28 AM
chris575m
Jan 2, 2011 04:46 AM
Springmountain
Sep 1, 2010 12:42 AM
kfouts2
May 22, 2009 10:19 AM
