supercharger pulley (15%, 17%)
It's the % the supercharger is OVERDRIVEN ... The JCW uses a 14.6% pulley ...
IMO I run the 15% as thats closest to "factory" specs and shouldn't adversesely affect the car ... The higher % pulleys will require additional mods ect to keep up with the overdriven pulley
i run a 17% alta pulley with K&N short ram intake, 8MM Jackson Racing wires, and NGK Cool Temp Iridium plugs and i love it. if u have at least those mods i would definitely go 17% once i receive my header i just bought im going to get larger injectors and an MSD coil pack and then upgrade to the 19% alta pulley as bad venge advised me.
Hey Joshua. I run a Alta 17% SC pulley but no lightened crank pulley. I do run an aftermarket cold air intake, colder plugs and an Alta exhaust. The shop I go to are Mini and Bimmer specialists. They said I didn't have to run a lightened crank pulley so I didn't.
bigk12345654123
Jan 3, 2010 11:06 PM
grandamvince
Jul 1, 2009 08:19 PM
joey50
Nov 10, 2007 02:56 PM
