R50 Getrag 6 speed conversion parts
I have the parts need for an R50 6 speed getrag conversion
I did this conversion, and then lost the engine a couple months later to bad compression. I spent around $3000 on this all when I bought it. The flywheel kit, axles, slave cylinder, and shift cables have less than 5000 miles on them. The gearbox had about 100K miles if I remember right. It had no problems in my car when installed. includes: Getrag 6 speed manual transmission (non-LSD, It is the BKE version with the desirable gear ratios) Driveshaftshop Level 0 axles with OEM bearing mount from R53 OEM Starter OEM clutch slave cylinder & pipe Valeo single mass flywheel conversion Kit (flywheel, clutch, and pressure plate) shift box +cables with short shift kit installed mounts brackets, bolts, etc prefer local pickup in Indianapolis freight could be arranged https://cimg6.ibsrv.net/gimg/minicoo...e9d034fc66.jpg https://cimg7.ibsrv.net/gimg/minicoo...3f96e6dc7b.jpg https://cimg8.ibsrv.net/gimg/minicoo...3d01e9c838.jpg https://cimg9.ibsrv.net/gimg/minicoo...8ca032f20a.jpg https://cimg0.ibsrv.net/gimg/minicoo...bf8d41b2e3.jpg https://cimg1.ibsrv.net/gimg/minicoo...1baee7c4d9.jpg https://cimg2.ibsrv.net/gimg/minicoo...a7149cc965.jpg https://cimg3.ibsrv.net/gimg/minicoo...7d2a43a39e.jpg https://cimg4.ibsrv.net/gimg/minicoo...2a3563420b.jpg https://cimg5.ibsrv.net/gimg/minicoo...3887094ea6.jpg |
to the top
This is still available
| All times are GMT -5. The time now is 02:38 AM. |
