R50 Getrag 6 speed conversion parts
Old Mar 28, 2023 | 07:43 AM
haledj's Avatar
Default R50 Getrag 6 speed conversion parts
I have the parts need for an R50 6 speed getrag conversion
I did this conversion, and then lost the engine a couple months later to bad compression.
I spent around $3000 on this all when I bought it.
The flywheel kit, axles, slave cylinder, and shift cables have less than 5000 miles on them. The gearbox had about 100K miles if I remember right. It had no problems in my car when installed.
includes:
Getrag 6 speed manual transmission (non-LSD, It is the BKE version with the desirable gear ratios)
Driveshaftshop Level 0 axles with OEM bearing mount from R53
OEM Starter
OEM clutch slave cylinder & pipe
Valeo single mass flywheel conversion Kit (flywheel, clutch, and pressure plate)
shift box +cables with short shift kit installed
mounts brackets, bolts, etc
prefer local pickup in Indianapolis
freight could be arranged
Old May 22, 2023 | 09:01 AM
haledj's Avatar
to the top
Old Jul 26, 2023 | 06:57 PM
haledj's Avatar
This is still available
Old Sep 7, 2023 | 08:06 PM
haledj's Avatar
Old Oct 4, 2023 | 01:43 PM
haledj's Avatar
Old Nov 1, 2023 | 11:31 AM
haledj's Avatar
califresh119
Mar 19, 2025 12:50 AM
KusoBabA
Nov 13, 2019 06:11 PM
StanP50
Sep 18, 2019 07:33 AM
colonelangus
May 19, 2019 10:27 AM
