-   Sights 'n' Sounds (https://minicooperforums.com/forum/sights-n-sounds-9/)
-   -   Flashing Red Light on Tach (https://minicooperforums.com/forum/sights-n-sounds-9/flashing-red-light-tach-6430/)
DBZMINI Aug 9, 2013 01:38 PM
I've been thru the owners guide 5 times and cannot find anything about a crescent shaped light over the large tachometer. I have not noticed it until I locked my door on a camping trip and in the darkness, this light started flashing. It got faster as the PM wore on. When I unlocked the door it stopped which I am guessing is part of the security system??? What does this light indicate, what do I do to stop it, and does it ever stop on its own?
I have a 2011 Mini convertible. Thanks a bunch!
ECSTuning Aug 12, 2013 09:40 AM
Visual indication of the factory alarm system.
Located at the top of the tach, upper red lens , little cresent shape.
http://c1552172.r72.cf0.rackcdn.com/39109_x600.jpg
http://www.realoem.com/bmw/diagrams/y/a/227.png
Here is the alarm kit for the R57, has a little more in interior sensor do to it being a convertible. Ultrasonic are are horizontal and behind the door panel and rear side panels. A little different set up then the hardtop.
R57 MINI Convertible Alarm. Part number 65732157425
http://www.ecstuning.com/Search/SiteSearch/65732157425/
Here is a link to the install PDF at the bottom to learn more about the system.
R57, Alarm Retrofit and location of Ultrasonic Module - North American Motoring
Here is the alarm maul page from 2012. Looks like is flashes then pulsates.
Thanks and hope that helps.
scoopers Feb 4, 2014 03:12 PM
Thank you for posting this info! Very good for future reference!
ECSTuning Feb 6, 2014 07:51 AM
You are welcome. :)
Jeffslaw Sep 6, 2019 03:56 PM
Red flashing light
I have the same problem. How do I turn off this red flashing light on top of the tachometer? The member explained the problem perfectly but I do not see the answer. The handbook does not help.
Jeff
ECSTuning Sep 10, 2019 03:46 PM
You can not turn it off, i would just leave it, its for notification that the alarm is on and armed.
