18 inch rims for for 2006 cooper s
Old Feb 23, 2010 | 01:01 PM
Kit Samonte's Avatar
Smile 18 inch rims for for 2006 cooper s
Is it possible to used 18 inch rim on 2006 Cooper S without modification. Please advise.
Old Feb 23, 2010 | 05:56 PM
I'm runing them ... 215/35/18 tires
Old Mar 8, 2010 | 04:17 PM
Bob 2009 rag top S manual's Avatar
Got an a 2009 S convertible with stock !6" rims. Will 18" work and what's the largest tire I can use and still stay under warranty. I may go to conventional tire instead of run flats. Would the sizes change depending on which tire I select. Thanks, Bob
Old Mar 8, 2010 | 06:27 PM
I'm running 215/35/18
Old Oct 28, 2010 | 07:29 AM
I'm just about ready to start my upgrade process from 16" to 18" rims and tires.
More questiones:
Knowing I will need to install turning stops, will there be a big loss in the cars turning radius?
I'm going with a non OEM rim 18X7 with a 52mm offset. OEM {John Cooper Works 18" rims} come with a 52mm offset. The dealer says the OEM rim will fit my 2009 S convertabile. I hope the mail order non OEM rims will also fit. I leaning towards the OEM tire size of 205/40R18 just to be sure all fits in the wheel well.
I'm not doing run flats. Leaning towards Michelin Pilot Sport PS2.
Any comments on my plan? Thanks, Bob.
Ivanstepul
Aug 13, 2013 05:24 AM
CaballesR
Jun 5, 2011 05:57 PM
javid8
Aug 4, 2009 09:22 AM
Peter434445
Jul 8, 2008 09:01 PM
04redline0124
Apr 15, 2008 10:56 AM
