2003 Mini Cooper Brake Pad Warning Light
Old 11-29-2011 | 06:01 PM
sbrewer715's Avatar
Default 2003 Mini Cooper Brake Pad Warning Light
Replaced the Rear brakes and checked the front brakes on my 2003 Mini Cooper S when the Brake PAd Sensor warning light initially came on. Everything seems to be clear now (Front pads good, rear pads replaced) but the warning light is still on. Please tell me this doesn't have to be reset by the dealer. Any ideas
Old 11-29-2011 | 07:27 PM
vetteburna's Avatar
I'm guessing you din't have the brakes replaced at a dealer. I'm a BMW ADP student and I can give you my best shot on this one.
As we all know these cars and modern day BMWs have a lot in common, whenever we do brakes on BMWs in the lab the codes have to be cleared using what BMW calls the "ICom". Its a fancy wireless device that plugs into the OBDII port to diagnose issues and clear codes. Only BMW approved facilities have this type of equipment, in other words you would have to take it to a dealer.
I'll double check with my instructor tomorrow and get back to you on this, I have access to dealerspeed.net, I checked there but couldn't find anything on this particular issue.
Hold on tight I'll get back to you.
Old 11-30-2011 | 11:53 AM
sbrewer715's Avatar
Thanks for the feedback. I can understand if it was the brake warning light, ABS etc, but it seems crazy to have to have the dealer reset the brake pad wear warning. Pretty much means no one except dealer can change brake pads, or you have to catch them before the warning triggers. Let me know what you find out.
Old 12-04-2011 | 11:21 PM
sbrewer715's Avatar
Just wanted to ask if you ever got a response from your instructor. Any feedback would be much appreciated.
Old 12-05-2011 | 01:13 PM
vetteburna's Avatar
Smile
Hey there,
Sorry about the delay I completely forgot to reply on this.
But anyway, basically who ever did your brakes dint replace your sensors that clip onto the pad from the back. Once your pads are extremely low the rotor begins to rub against the plastic tip of the sensor, eventually the sensors' metal end becomes exposed to the rotor. Once it does, it completes a parallel circuit that consists of all four sensors, leading to that light on your dash to go off.
Simply replace those sensors and before starting the car, keep the key turned all the way. Do not crank your engine, if you do the system will refuse to reset. You have to keep the key on ACC for about 5 mins, after doing so you may start the car, you will notice the the light is no longer there.
Let me know how it goes, good luck
Renan
Best regards
Old 12-05-2011 | 05:10 PM
Sensors are cheap $9 or so
metubbs
07-07-2014 01:41 PM
Hawkfan72487
10-01-2012 11:20 PM
spencerbrog1
06-16-2012 05:47 PM
Sinnerman
10-04-2008 04:00 PM
socko
02-29-2008 02:10 PM
