air pressure sensor removal
if I mount new tires without the air pressure sensor will I receive signals that I have flat tires?
yes if you are putting on different rims/tires without the tpms sensors
if you are mounting tires on the stock rims with the sensors you'll have to reset them and you should NEVER mount runflats without tpms sensors |
i've got an 06 cooper S. i thought that the pressure sensor was actually just a sensor monitoring the rotation of the four tires not the actual pressure, thus if a tire was low, its diameter would be smaller making it turn faster in order to travel the same distance as the other tires. Am i wrong on this? If i am correct and all that it's doing is monitoring the rotation then i'd be safe to put my other wheels on wouldnt i? i have a set of 17" konig verdict wheels with winter tires on them from my 03 sentra that i used to have.
Is it safe to mount 17x 7 rims with a +45 offset on my 2010,clubman S?
first gens do not have tpms in the wheels ...
second gens run wheel sensors ... yes ou might be able to run the sentra wheel I'm not sure of bolt pattern/offset and I believe I answered YES I'm running 17X7's 45 offsetobbie |
Thanks! Just wanted to make a rim application double check! Thanks again I will order my new rims directly!
2 Attachment(s)
my sentra had a 4x114.3 bolt pattern but the wheels im referring to are a universal 4bolt pattern i believe.
they were white but i painted them a charcoal grey Attachment 272 Attachment 273 |
As long as the other pattern is 4X100 and correct center bore and offset
| All times are GMT -5. The time now is 06:20 AM. |
