Rotor Replacement
Old Mar 9, 2013 | 12:57 AM
Default Rotor Replacement
What size is the Torx bolt that holds the rotor on on an 05 cooper S ?
Old Mar 26, 2013 | 12:41 PM
Torx head size T50 .
The bolts should be replaced every time you do a brake job / rotor change and you can apply the anti seize to the head of the brake rotor screw.
One rotor screw per rotor.
http://www.ecstuning.com/Search/07136772426/ES16458/
Thanks and let me know if you need anything else.
Apr 3, 2014 01:35 PM
Apr 3, 2014 01:34 PM
lmalbright
Aug 24, 2012 05:38 PM
wallmart TP
Mar 12, 2009 05:57 PM
wallmart TP
Oct 15, 2008 05:14 PM
