04 Mini Flat Tire sensor
Old Jul 4, 2011 | 03:33 PM
surfndude44's Avatar
Default 04 Mini Flat Tire sensor
I had two new tires put on the mini two days ago and now the Flat Tire Monitor is on solid and yellow as soon as you start the car. I checked the tire pressure in all 4 wheels and adjusted them to be the same. I tried reinitalizing the system but that did not help. Thanks in advance for any suggestions.
Tom
Old Jul 4, 2011 | 04:25 PM
Interesting, I went thru the reinititializing steps and the light is off now.
I'll keep my eye to see if it returns but all is good at the moment......
Old Jul 4, 2011 | 05:35 PM
"new" tires have more tread and a different diameter so you have to reinitialize the system you might have to drive a bit to reset it
Coopermini
Dec 4, 2022 10:13 PM
terencekent
Jan 19, 2018 06:27 PM
hatrabbit
Feb 22, 2012 09:55 AM
XCM828
Sep 15, 2008 09:57 AM
jeff@redlineperforma
Dec 19, 2006 02:21 PM
