AC not working on 2003 mini cooper
Old Aug 29, 2010 | 09:54 PM
localminicooper's Avatar
Default AC not working on 2003 mini cooper
A/C not working. I checked the relay and that seems okay. I put 12 volts to the clutch on the compressor and was able to make the ac turn on with the relay removed.
Does anyone have any suggestions?
Old Aug 30, 2010 | 07:41 PM
Limit switch/pressure switch not engaging
Old Sep 5, 2010 | 11:52 PM
Default Ac not working
Thanks for the reply Bad Venge---where is this limit/pressure switch located---is there a diagram you can share?
Old Sep 6, 2010 | 11:17 AM
If the switch is not engaging the charge is likely low and needs a recharge or at least a charge check
Jat007
Jul 6, 2015 09:49 PM
arahsay
Apr 19, 2012 09:50 PM
perkman
Sep 6, 2008 08:34 PM
neocoyote
Apr 11, 2008 05:04 PM
1fstmini
May 26, 2005 11:54 PM
