Wheels and tire help
Just got a 2010 Mini non S and it came with the 15 inch and RF. It really looks like I'm riding a go cart so looking at upgrading wheels and tires. Do 17 inch wheels with non RF still give you a rough ride? Should I go with 16 inch wheels and non RF tires? Will 16 inch make any difference in look that the 15 inch on now?
I had a car prior to my mini that I had 17 inch winter tires on and in the summer I had 18s that I put on. As is the case with low profile tires because if the shorter sidewall there isn't as much flex when you go over things like bumps in the road, potholes or railroad tracks. Non run flat tires will be softer but going from a 15 or 16 to an 17 or 18 will probably almost completely negate the difference.
If you live somewhere where the roads aren't generally perfect year round I would suggest either staying with the smaller wheel size and maybe if u want find an affordable spare set to swap out occasionally.
I acquired one Used Jaguar car which was having 16 inch wheels. At that point I found that when I changed from 16's to 17's, I had a much harsher and unpleasant ride. So I recommend you to pick 16 or 15 inch wheels.
madam04
03-22-2013 08:30 AM
ggboy
10-18-2011 02:07 AM
