HELP !!! I want to MANUALLY drop the top
Old Mar 1, 2008 | 12:52 PM
pditty0069's Avatar
Default HELP !!! I want to MANUALLY drop the top
Can anyone out there give me a step by step explanation on how to manually drop the top on my 2005 convertible mini?? Also, does anyone know of any after market parts that i can get to have it repaired...it stopped working RIGHT after the warranty went out...the passenger side of the sun roof part will go back but the motor on the driver side is not functioning (or it is stuck or something)...PLEASE help...moving to L.A. soon and I would love to be able to drop the top again...its been over a year now !!! thanks, Preston
Old May 21, 2008 | 12:50 PM
KevinAccord's Avatar
Default RE: HELP !!! I want to MANUALLY drop the top
if I were you I would just pay the extended warranty to 100k milesfor $1,500... it's gonna be cheaper than repairing whatever breaks b4 the 100k miles....
Old Oct 2, 2008 | 06:21 PM
ymperformance's Avatar
look in the l/r and youll see a pimp, inscrew the flat head screw about 1/2 turns. inside the veh right over your head there is a plastic cover, remove the cover and disconnect the motor. there is a hex shaped shaft that if you turn with a hex socket, the top will begin to open.
2easilyamused
Feb 22, 2013 07:05 AM
Monica Sara Cortez
Jul 30, 2012 06:26 PM
OrangeFlavor
Apr 23, 2012 07:47 AM
lowproguy91
Jun 9, 2010 02:26 AM
showgram
May 17, 2007 10:56 PM
