2011 R56 S major squealing
Old Oct 11, 2016 | 10:33 PM
Minikidd's Avatar
Default 2011 R56 S major squealing
See the video to the end. Has anyone encountered this?
You tube video:
I know that the valve cover is leaking but the latter noise is troubling.
2011 R56 hatchback with 68K miles.
Old Oct 18, 2016 | 10:42 AM
PelicanParts.com's Avatar
I'm wondering if that is a hissing sound we hear. If your valve cover is leaking, it could be allowing some sort of vacuum leak. What I recommend doing is a smoke test of the vehicle. If there is a vacuum leak somewhere it will pinpoint exactly where it's coming from. A local MINI independent shop can do this for you if you do not have a smoke tester. As you can see a smoke tester is not cheap: Pelican Parts - Redline Detection Smoke Pro Total Tech. Let me know what you find.
bad venge
Nov 1, 2016 01:42 PM
bad venge
7
Jun 27, 2015 09:01 PM
chris410
Sep 24, 2011 03:08 PM
themenace
Jan 7, 2009 12:25 PM
lawdesk
Jan 24, 2008 11:00 PM
