Cant shift lever to Park
Hi
I just purchased a 2007 mini with automatic transmission. Everything was working fine until I did an emission test to it. When I went home from the emission test I could not put the gear to Park Mode. It can go to Neutral, Drive and Reverse but for some reason it will not shift into Park Mode? I have no idea what's happening and would appreciate your expert advise. I have no other choice but to park in neutral.
Thanks very much in advance for your support.
Its it and automatic , its could be the lug base or the cable going to the top of the transmission ? Have you inspected either ? You have to make sure also that your foot is on the brake pedal while you do it , switching into park.
thanks
thanks
michaelkieth
Mar 7, 2012 03:25 PM
wheelsI really do like some of the newer rims available on the park avenues'. Does any one know if n
andrew65
Jan 28, 2009 07:37 AM
