Diesel fuel pump
Old Nov 13, 2020 | 09:42 AM
RichieD's Avatar
Question Diesel fuel pump
Hi,
I have a Cooper Diesel 2009 and it looks like it wont start because it's not getting fuel....
The tank is 3/4 full and I've removed the rear seat and panel to gain access to the in tank pump. I've removed the electrical connector and there are only 2 pins. I've checked the voltage across these pins on the cable when cranking and there's nothing. I was expecting to see 12V
From what I've seen on the web this unit is both a pump and fuel level gauge but this can't be with only two pins. I assume it is only a pump. Has anybody come across this and can confirm that there should be 12V across the pins please?
This is the in tank pump with only 2 pins
saxtell74
Mar 22, 2021 08:41 AM
RichAromaCoffeeCo
Sep 8, 2019 05:43 AM
Apr 25, 2013 12:44 PM
MiniLenny
Mar 20, 2009 10:56 PM
