Electrical problem with power windows
Old Apr 25, 2020 | 02:26 PM
Reggie77's Avatar
Default Electrical problem with power windows
I’m having intermittent problems with my power windows.
At times when I press the switch to roll my driver side window down, both windows go down all the the way. When I try flip the driver wide window up to close the window, the lights on seat warmer button goes on instead.
I have to wait several hours for it to work again.
Any idea what could be causing this? Seems to be some sort of electrical issue.
Old Jul 18, 2020 | 12:46 PM
Erica Craig's Avatar
Reggie, Did you ever find out what was going on with the mini? I am having the same exact problem.
Old Jul 18, 2020 | 12:54 PM
Reggie77's Avatar
Yeah, my mechanic cleaned the contacts on the ECU module by the driver and passenger footwell.
My mechanic said there’s a known issue with water leaking from the sunroof down to the ECU module. He checked and saw that the tubing was already replaced to prevent leakage, but said that the contacts probably wasn’t cleaned out and deteriorated over time.
Old Jul 18, 2020 | 12:58 PM
Super! Thank you for the quick reply! You may have just saved me a huge headache trying to figure this out!
Old Jul 18, 2020 | 12:59 PM
Reggie77's Avatar
Hope that works for ya. Good luck !
glennrockowitz
Aug 27, 2017 02:28 PM
retromike3
Mar 9, 2016 11:38 PM
prettypinkcloud
Oct 19, 2014 08:20 AM
watermantra
Jun 9, 2009 09:21 PM
perkman
Sep 6, 2008 08:34 PM
