Engine Change (Does it make a difference Man to Auto)
Old Sep 19, 2016 | 01:51 PM
velobello89's Avatar
Default Engine Change (Does it make a difference Man to Auto)
I have a 2009 Mini Cooper 1.6 Base I am repairing and looking for a replacement engine. My car is an automatic transmission and the replacement engine I found is an manual transmission. I will be rebuilding the engine myself and was wondering if there is a difference between the crankshaft from a manual car and automatic?
Old Sep 20, 2016 | 10:23 AM
PelicanParts.com's Avatar
It will be an expensive swap as you'll most likely need new pedals, a clutch, flywheel, a new ECU and other things. It's easiest/cheaper to replace with what the vehicle came with. I'd recommend looking on Car-Part.com--Used Auto Parts Market to find a used engine that will work with your R56. If you need any other misc. parts please don't hesitate to let me know
2009 Mini Cooper Base Hatchback Parts and Accessories - PelicanParts.com
tim2004
Apr 20, 2014 04:46 PM
sneedspeed
Feb 4, 2014 10:04 AM
sneedspeed
Jan 11, 2013 04:24 PM
CMZee13
Apr 22, 2005 10:42 PM
