Newbie questions
Old Jan 29, 2011 | 09:30 AM
scbimmer's Avatar
Default Newbie questions
I have purchased an 07 Cooper S and had a couple questions:
- Is there a way to adjust the armrest? It is too low and the emergency brake hits it when engaging the brake. It doesn't seem very stable either.
- I am trying to set the remote lock/unlock to flash lights and sound horn. The only option available is flash lights. Will the audible option only be included if I have the alarm system? That's the only reason I can come up with.
- When opening the sunroof the roof reverses when about half open. If I pulse the switch at that point I can get it to open past the halfway point.
Thanks for the help
Old Feb 8, 2011 | 09:44 AM
Laser Blue mini's Avatar
I have the same yr Cooper S and the sunroof had to be reprogrammed because it didn't want to open. I'm still learning the remote stuff too. I only had the Cooper a short time.
Old Feb 8, 2011 | 07:44 PM
Armrest is a fixed height but if the former owner pushed too hard they break and lean downward
I don't think sound is an option
Sunroof I'd try inspecting lubing the track you might have an obstruction
if not it could need reprogramming
1953drtelco
Jan 2, 2013 07:33 PM
tymbom
May 19, 2011 11:27 PM
agreenberg1977
Jun 22, 2008 01:33 PM
