08 Clubman Headlamps
Old Apr 4, 2016 | 05:34 PM
purple_monkey_dishwasher's Avatar
Default 08 Clubman Headlamps
Hey guys and gals,
so I have an 08 clubman and I have run into an issue where my high beams won't engage. The low beams work and when I switch the high beams on the icon pops up but the headlamps don't respond. I have checked the fuses and none of them are blown so I'm thinking there is a relay switch somewhere that possibly needs replacing.
Has anyone run into this problem, and if so how did you fix it?
Cheers!
Old Apr 5, 2016 | 01:46 PM
PelicanParts.com's Avatar
Do you have a bulb out indicator? Sounds silly, but just double check to make sure the bulbs aren't burnt out as it's not uncommon for them to go out in pairs at times.
Old Apr 5, 2016 | 03:15 PM
I do have a bulb out indicator, but I believe that is due to one of my running lights being out. The the bulb for my lights is a low/high combo. No separate bulbs. That is what is stumping me.
zacbaz
Jun 20, 2011 06:02 PM
lovemyredmini
Jun 23, 2010 05:59 PM
