Check engine light
Old Aug 23, 2018 | 06:20 PM
Somp's Avatar
Default Check engine light
Hello. Check Engine light is on but OBD2 reader says no codes. Searching for codes while ignition is on and engine isn't running. Is that the correct procedure? Borrowed a second scanner and got the same "DTC 00" value. Anyone ever experience this? Model: Clubman, Year: 2009, OBD2 code reader $20 Performance Tech from Pepboys (maybe this scanner is a known problem for Mini's?). Thanks.
Old Jul 25, 2019 | 11:08 PM
paddesa76's Avatar
I recently purchased a 2009 Clubman S and I have a similar issue. Reduced power comes on on the dash and eventually the check engine light comes on. Then it goes off for a while. 2 different scanners come up with no codes detected. Did you ever find a resolve for this? I really like the car, but if this is how it's going to be I might have to cut my losses and buy something else already.
jim427
6
Feb 15, 2024 06:54 AM
Darrinos
Jun 22, 2022 01:56 AM
Scott Allen
Jul 5, 2019 05:04 PM
a16344
Feb 6, 2010 06:40 AM
