Head gasket/timing chain
I have '06 mini base model. Need to replace head gasket. ( Actually need to replace a few burned valves due to heavy carbon build up ). Besides gasket set, new head bolts and new camshaft sprocket bolt, is there anything else I will need? Also, how do I re-time cam and timing chain when putting back together? Any advise or suggestions would be great. ANy only have any idea how long a job this is?
Thanks for the advise. Just ordered a Haynes guide I'm sure it will be well worth the $25 investiment. I saw photos on line where some one
removed timing chain sprocket and kept tension on it upward with head off to avoid having to re-time. Any one able to do this successfully, any
ideas of how to get head off while keeping it pulled up ward would be great
