Manual Transmission BLOWN - - - THE FIX!!!
Old Nov 15, 2021 | 07:58 PM
  #61
MinimizeMike's Avatar
Default 101,000mi - transmission cracked!!
my 2002 MINI Cooper was in great shape! One of the first 50 in the US! One day last week I couldn’t get it into first gear, and was able to limp into the shop. Tranny is cracked Internally and mechanic said these early Transmissions are delicate little buggers. I wish we could go back on BMW over this! It isn’t right! Engine is great, 5-speed Manual. Is it worth fixing!?!?
I can’t even find a decent priced salvage transmission to put on this to get back on the road, advice?!
mmkimble@gmail.com
Originally Posted by xwiredtva
Ok, my mini has had a SHORT life so far. It's been well cared for by two owners (I'm one) and garaged it's entire life (I called and spoke to the original owner - ALWAYS take your stuff out of the CAR!). She was not a happy camper with it either BTW.
After 2 weeks I got it back and had a LONG LONG Talk with the mechanics at the BMW Dealership (Mini USA offered "Good Faith" discount of $500 after a $900 towing charge- IE: More expensive). The one mechanic worked for a Mini dealer in MD. He said his JOB was replacing transmissions, that's all he did (sound like there's a problem?). He said BMW knows the problem, knew of it when they put the Midlands boxes in the car but figured they would last past the warranty long enough to sell the cars and it worked we all got suckered into them. This is also why the 2006+ have 6spd Getrags (same ones used by GM on the SS Cobalt BTW).
He said the ONLY way to keep these from breaking is to change the oil at 7500 miles. Use synthetic and hope for the best. The problem is in the bearings on the shafts. He showed me on mine where it failed. The bearing shreds then the bits get jammed into the gears which causes them to break apart. There not double heat treated gears so they are brittle but strong. Double heat treating would give them some flex which may actually cause them to bend and break up faster.
As for the CVT's when I asked he just laughed. He said every 5k miles change the fluid. Not sure if you can add a oil cooler to the auto's but it's all about the heat deteriorating the oil which causes the system to fail.
So there you go from the horses mouth, change the engine oil change the tranny fluid. Also on new boxes he reco'd changing at 500 then again at 3000 miles.
2006+ don't have transmission problems. He said he never worked on a 2006 or newer unit and he worked for them until Dec 2007.
Also when you replace the tranny replace the mounts too. The BMW dealer actually replaced them at no charge for me as well as the flywheel IF the gears punch a hole on the clutch side of the box itself. The core charge for the tranny is now $1000.
Old Dec 11, 2021 | 03:30 PM
  #62
opm's Avatar
opm
Originally Posted by sparkyj
I have a 2002 with a trans that is starting to Whir and not shift into 3rd gear properly. This was after a broken shift fork was replaced and we replaced the clutch while the trans was out.
I I had the same problem happened to my it's happened to my 2005 R50 the and replaced the shift fork and clutch clutch and now I also have a whirring 5 speed. How did you remedy your situation? Did you purchase a get rag 6 speed and do the conversion?
Old Nov 21, 2024 | 06:27 AM
  #63
Newlands's Avatar
Originally Posted by erk187
Scroll up and read past messages. I rebuild them for 800 bucks. I should write a book on rebuilding them...
DO you still rebuild and what's your location if you do? I just bought 03 manual transmission mini and had it 3 weeks before it's whining and grinding
bigdork
75
Oct 11, 2021 12:35 AM
Nikegal1
May 6, 2013 09:47 AM
ericyingling
Dec 28, 2011 10:55 AM
geomeo123
Dec 25, 2011 02:52 PM
MiniWheats
May 10, 2010 07:39 PM
