Mini cooper door wont open not actuater
Old 12-20-2011 | 09:03 AM
IHATEMINIS's Avatar
You need an actuator
  #12
Old 12-20-2011 | 08:53 PM
seizurel8r's Avatar
Originally Posted by orca17
I'm having a problem with this now - only I can open the door from outside, just not inside. The actuator works fine.
I seem to have a working solution to the problem of the Bowden cable popping out of the latch assembly. I made a "U" bracket from 1/16" aluminum about 3/4" wide. One leg is about 1 1/4" inches long and the other leg is about 1" long. The bracket inside width is about 1 1/8". This bracket can be slipped over the top of the latch assembly (and over the Bowden cable tip) to prevent it from popping out. Long leg goes between the door skin and the latch assembly. The fit needs to be tight enough to keep it in place but not so tight as to cause binding (which happened to me the first time). I has been working for over a month now and I will be doing the same for the passenger door. I can get some photos and actual dimension when I fix the passenger door if you are interested (and assuming you are having the same problem).
dima1616
07-21-2023 07:16 PM
tompr
01-03-2022 08:57 PM
b1bby
01-07-2014 10:38 AM
NiuNiu
06-06-2011 05:09 AM
gymrat
06-19-2009 10:12 AM
