Mini Cooper intermittent clutch failure
Old Jul 19, 2023 | 08:49 AM
miniproblems's Avatar
Unhappy Mini Cooper intermittent clutch failure
Approximately 10 times over the last 8 months the clutch pedal had dropped to the floor, we have had the master cylinder replaced twice, the slave cylinder replaced once, the clutch fluid drained and changed twice in between, there appear to be no fluid leaks or air in the system. Once the pedal drops to the floor you can pull it up with your foot and then get the car into gear again to limp it off the road, then if you leave the car standing for an hour or so the clutch comes back to life and will work fine for another few weeks - any suggestions would be very welcome as it seems to be an impossible problem!
Old Nov 16, 2023 | 04:40 AM
ecotecin's Avatar
i have had this same issue a couple of times. Ever figure out anything about it?
Old Nov 16, 2023 | 04:54 AM
Sorry no, we even resorted to replacing the whole clutch only for it to re-occur 6 weeks later, finally decided it was the end of the road and got rid of it! Good luck with yours....
Kirk Schwien
May 27, 2020 07:43 PM
JohnDeVenney
May 22, 2017 07:25 PM
surfndude44
Oct 17, 2011 01:41 PM
yesfaninsf
Mar 15, 2011 10:39 PM
poliveira87
Dec 20, 2008 07:05 AM
