Need help on 2006 Cooper S
I need help on figuring out why my cooper is hesitating on acceleration. Is anyone having this type of problem? If so, all help is appreciated. Once passed a certain RPM, it is fine. Thanks!
+1 on checking the throttle body. Have you thrown a check engine light code ?
Throttle body might need cleaned or it might be failing.
For The Cooper S gen 1 :
Throttle Housing / Body part # 13541503358
http://www.ecstuning.com/Search/SiteSearch/13541503358/
The butterfly valve should be clean like this , when gunk build up it sticks on the first throttle and releases.
If its bad / needs replaced. It throws a throttle code.
lakeober
Jun 18, 2013 05:55 PM
Yardley
Nov 26, 2012 08:18 AM
Lhall3489
Apr 20, 2012 10:58 PM
Kalinchuk
Oct 13, 2010 09:29 PM
