R50 2006 stiff ride
Old Oct 21, 2012 | 09:37 PM
Bugoy06's Avatar
Default R50 2006 stiff ride
I just bought a pre-owned 06 R50 and noticed that I felt almost every bump on the road. I do not have run flat tires; the tires that are on are 195/55/15 Kumho. On the highway, it runs fine.
Also, when driving at a speed of under 20 mph, I feel the engine's idling is not smooth- almost like a jolting motion when I release the accelerator.
Any ideas?
Thanks.
Old Oct 24, 2012 | 11:19 AM
PelicanParts.com's Avatar
How many miles on the car?
Old Oct 24, 2012 | 06:29 PM
Boost's Avatar
Does it have any mods?
Old Oct 25, 2012 | 07:29 PM
Bugoy06's Avatar
76000 miles. No mods.
Old Oct 26, 2012 | 12:02 PM
How do the tires look? Also check the shocks and strut mounts.
Old Oct 26, 2012 | 06:16 PM
Bugoy06's Avatar
The tires are new. I don' t see anything wrong with the shocks and struts but will have them checked.
Old Oct 26, 2012 | 07:44 PM
Boost's Avatar
It kind of sounds like you have a CV joint going out, could you be mistaking the idle noise for CV joint failure. If the noise only happens when you are moving it is probably the CV joints. Does the noise get louder or change when you turn a corner? If you have a lot of noise and vibration when you accelerate you might have a bad inner joint.
Old Oct 29, 2012 | 08:59 PM
  #8
Bugoy06's Avatar
I do not hear any noise when turning. It just bumpy when running on uneven surfaces or bumps on the road.
The jolting motion almost feels like the gas has water mixed in it.
surferian
Jul 14, 2018 01:20 PM
kayakman19
Aug 10, 2013 10:00 AM
troywk
Jan 20, 2012 07:59 AM
redlinetimeattk
Jun 2, 2010 07:13 PM
JCW R56 Turbo
Sep 8, 2009 10:29 PM
