Exterior Talk about your rims, body kits, and other exterior mods here.
aftermarket hids
Old Dec 22, 2012 | 09:20 PM
Chased's Avatar
Default aftermarket hids
What brand are guys running?
Old Dec 23, 2012 | 07:36 AM
FIRST you need to get the projector type housings or the factory HID housings...
I'm running ddm tuning HID's
I've also used hid extra ones with good results
Old Dec 23, 2012 | 08:47 PM
Chased's Avatar
Why can't I use the housing that it has
Old Dec 23, 2012 | 09:07 PM
HID's on a standard housing has no cut off/focus and will blind oncoming drivers ...
This has given HIDS the bad name they have by putting hid bulbs into standard housing...
Old Dec 23, 2012 | 09:40 PM
Chased's Avatar
I have them in my trailblazer SS with stock housing and they are great
Old Dec 24, 2012 | 03:40 PM
Great for YOU ... Not for oncoming drivers
Old Dec 25, 2012 | 07:11 AM
Chased's Avatar
Wow dude thanks for the welcome you need to calm down! I guess caddy Lexus VW and all the other builders could care less about it also. As very few use a projection beam
Old Dec 25, 2012 | 07:43 AM
  #8
First off you come asking about HID's and what you are running I give you the info and WHAT needs done to run them properly...
Lexus and VW use specially designed housing FOR Hid's ... And far different then just popping HID bulbs in halogen housings.
All the Caddy's I've seen ARE using projectors as are BMW/Accura/Audi Ect
They are designed with bulb sheilds , and special reflectors to focus the beam and give it a cut off preventing blinding oncoming drivers.
Projectors are the best easiest way to give the beam focus and retrofit into housings.
look at retrofit source
Heres some light reading on the subject
http://aseclub.net/forums/index.php?...1#entry1294631
BigBran
Feb 18, 2017 06:35 PM
preludestuntin
Jan 7, 2008 10:15 PM
3X82
Oct 1, 2007 06:36 PM
karbonkraze
Apr 1, 2006 09:37 PM
karbonkraze
Apr 28, 2005 07:55 PM
