'09 Clubman Won't Shift from Park
Old Jan 28, 2018 | 11:16 AM
Zooberwerx's Avatar
Default '09 Clubman Won't Shift from Park
Recently purchased a new-to-me 2009 Mini Cooper Clubman. Runs fine and got it home from the seller with a couple stops in-between. Today, the vehicle will not shift out of park (P) with the engine running, brake pedal depressed, etc. Per manual instruction, I used the "key" provided in the tool kit and removed the yellow pin which is supposed to over-ride the interlock...it did not work. My search on the internet has provided only less-than-definitive responses.
If anyone can provide suggestions and/or authoritative links, I'd be most appreciative! Thanks for the accommodation!
Edit / Follow-up: Apparently, the shifter inter-lock has a history of getting stuck due to the mechanism itself. I gave the **** 3 military-grade downward blows which resolved the problem. I'm also now seeing an alert signal which confirms the inter-lock is now bypassed. Shifter inter-lock tool & pin
Old Mar 16, 2025 | 12:07 PM
DYI One's Avatar
Mine has the yellow tool cut. Is there a place to order this. Thx
Mnaylor
May 26, 2023 11:20 PM
Steeler
Jul 20, 2022 11:36 AM
sneedspeed
Oct 31, 2016 12:59 PM
Twain427
Nov 15, 2011 01:02 PM
t1 3vom
Apr 27, 2008 10:43 PM
