2006 Mini Cooper S Rad Fan Low Side
Old Jul 14, 2016 | 06:46 PM
flyguy124's Avatar
Default 2006 Mini Cooper S Rad Fan Low Side
Hello all,
I have a 2006 Mini Cooper S that I recently purchased. I noticed that I'm getting some very strange fan cycles. First, when the high side fan kicks in, my supply drops from a perfect 14 V to about 12.2 to 12.1 volts, then back up when it shuts off so I'm wondering if that's an issue or if it's common to draw that much. I also don't seem to have a low side fan engaging. I tested the relays which are all functioning and the low side terminal is supplying 14 V but the fan is not kicking on to the low setting, only the high setting. This is only an issue when I'm idling with the A/C on since that seems to be the only time the fan is even engaged at any point. Should I replace the fan? Is my alternator not strong enough at idle? It sounds like one side of a resistor has failed but the other resistor works fine.
fiatosca
Mar 10, 2016 12:32 PM
James Riding
Mar 25, 2015 08:23 AM
Jun 5, 2013 01:46 PM
drewboss
Oct 5, 2011 12:21 PM
kthomas
Jan 6, 2011 01:10 PM
