Glove box fix for free
Old Sep 13, 2011 | 01:00 PM
Blackbeast's Avatar
Default Glove box fix for free
Figured out the best kind of repair (FREE) for the glove box door falling open all the time. I have seen several posts on this, so here is what I did. Take the glove box out, then remove the part that the handle catches on. There are two nuts/bolts. CAREFULLY grind down the flange around the bolt holes to about 1/8 " thick. Be careful because the plastic grinds away fast. Then reattach it, close the door, and see if it falls open when you shake it. If it does, grind a little more. Mine stays shut with about 1/8" left. Best part of all, it's free if you have a grinder. Takes about 10 minutes with a grinder from start to finish. A file will probably work but take longer.
Timini
Jul 8, 2010 01:39 AM
Timini
Sep 4, 2009 08:50 PM
pinermel
May 11, 2008 06:21 PM
Timini
Feb 4, 2008 02:21 PM
newtonjosh4
Oct 10, 2007 12:06 PM
