Leaking power steering fluid
Old Dec 16, 2012 | 03:05 PM
MARIO967BLUE's Avatar
Cool Leaking power steering fluid
Just purchased 2005 mini cooper s auto,,74,000 miles very clean almost mint noticed fluid front middle of engine on ground looks like power steering fluid,No whining of pump steers normal,little low on fluid now,,any idea ,is it pump,,or just hose leaking, have heard that these cars have pump problems.Will take it to my mechanic just wondering what it could be thanks,,Mario
Old Dec 16, 2012 | 06:33 PM
not near enough info to give you an exact ... could be either listed or a bad rack and pinion assembly
Old Dec 17, 2012 | 12:00 PM
PelicanParts.com's Avatar
If you have a floor jack, you can check underneath the car for some signs of where it's coming from - you can also clean up the area a bit then check later for any new signs of fluid/oil.
Old Dec 18, 2012 | 05:45 AM
Default power steering fluid
Looks like its coming from the pump area ,car rides great no whining of pump..hope its just a hose,seal etc,,
Old Dec 18, 2012 | 12:02 PM
If it's the pump, or anything connecting to it, and you feel up to replacing the faulty part yourself, check this out as a guide: Pelican Technical Article: MINI Cooper - Power Steering Pump Replacement
Old Dec 26, 2012 | 11:49 AM
Angry Leaking power steering
Wondering where power steeering leak is coming from,looks like its coming from under pump,,steering works fine very little whine witch i understand is normal for these cars,,do understand that hoses are a common problem ,,any idea ?????????
Aug 19, 2013 01:11 PM
rocamini
Dec 11, 2011 12:22 PM
Alan
Jul 19, 2011 10:38 AM
saab92xer
Oct 6, 2009 07:34 PM
Randy Lawson
Jun 26, 2007 06:51 PM
