mini cooper footwell module
Old Jan 23, 2018 | 06:47 PM
Jackson A Mclean's Avatar
Angry mini cooper footwell module
Any Body have problems with the footwell module ? seems to me that might be my problem
Old Feb 7, 2018 | 11:47 AM
PhatBrian's Avatar
Member
footwell modules are common issues in mini as well as bmw. if your footwell module has corrosion you need to see where water is getting in from. most of the time the sunroof drains detach and drain directly down the a-pillar inside the vehicle.
Old Mar 21, 2018 | 07:23 PM
Minitobe's Avatar
Member
It could also be covered under warrenty from mini. Give them a call.
Old Mar 21, 2018 | 08:05 PM
PhatBrian's Avatar
Member
They won't cover it if it has water intrusion.
Old Mar 21, 2018 | 08:09 PM
Minitobe's Avatar
Member
Maybe true...it is an easy swap with a unit that has the same part number. ISTAP can program and code it with no issues.
ransome
Jul 25, 2016 06:34 PM
lunch box
Sep 15, 2009 10:00 PM
mindicooper
Aug 17, 2009 05:54 PM
