Mini power steering res
Old Mar 8, 2017 | 09:10 PM
Nate85's Avatar
Default Mini power steering res
First hello. This is my first post but im sure not my last. I bought a 2007 mini cooper last week and am fixing a few things on it. The ps started to whine. After googleing for hours and looking around the engine bay i see no ps reservoir. The coolant expansion tank is located in front of the engine. I do not see the typical bmw style reservoir anywhere, where is this located? It is the naturally aspirated engine. Thanks for your help!
Old Mar 8, 2017 | 09:15 PM
Nate85's Avatar
Also i should mention that there is zero mention of anything power steering related in the manual
Old Mar 8, 2017 | 09:19 PM
Nate85's Avatar
Ok so i found that this car has a servo, probably why i could not find anything power steering related. Now does anyone have any idea what a whinr that sounds identical to a power steering pump could be?
Old Mar 13, 2017 | 09:10 PM
bojo538's Avatar
Not sure if I am posting correctly new to the site but I have a 05 Cooper and it hesitates
when shifting between gears and when you rev the engine while idling. Any idea
Old Mar 16, 2017 | 11:57 AM
PelicanParts.com's Avatar
The power steering in the R56 is entirely electric power assisted. They use fully "electric servo" power assisted steering with a motor geared direct to the steering rack with no hydraulics or fluid reservoir and less noise. Can you post a video of what you're hearing?
Old Mar 16, 2017 | 11:58 AM
You'll want to start your own thread, but are there any fault codes in the system? Check all modules. When was the last time you replaced routine maintenance items?
cturner7
Nov 18, 2014 08:10 AM
Aug 19, 2013 01:11 PM
KCH1234
Oct 17, 2011 08:44 PM
Alan
Jul 19, 2011 10:38 AM
truffing351
Oct 28, 2010 08:02 PM
