Sticker removal....help!
Old May 2, 2008 | 09:56 AM
thunderhead's Avatar
Default Sticker removal....help!
I'd like to remove the airbag sticker on my dash.
Any suggestions ?
Was going to heat gently with a hair dryer and use some dental floss to go between or just try to peel off. After that I planned on removing the remaining glue with WD 40.
I have the anthracite dash on a 08 "S" convertible.
Thanks for your input
Thunderhead
Old May 2, 2008 | 11:35 PM
cougsfan's Avatar
Default RE: Sticker removal....help!
I used a hair dryer and it was a pain to get off but did come off. I used a little gas on a rag to get the remaining glue off. (Someone will probably roast me for being so barbaric, but gas works pretty good if you use common sense.)
Old May 3, 2008 | 07:42 AM
[:@]3M adhesive remover is FAR FAR safer then gas
OREGON07S
May 22, 2012 01:16 PM
artofjosh
Feb 15, 2012 10:29 PM
gt4play
Mar 2, 2011 07:32 PM
chris_norcal
Aug 17, 2009 06:32 PM
riata_ag
10
Jun 22, 2008 12:14 PM
