Originally Posted by dschmale https://minicooperforums.com/forum/i...s/viewpost.gif BMW tech. No Longer Active.
Last activity was 2009 so he is no longer on here for a very long time and he was not a paid sponsor. I see a lot of his PMs went unanswered. So if you need help I am here for you guys. :) |
my mini cooper s has been at Midas for a week now..they can not find the problem..I thought I had left the hatchback ajar and ran the battery down..next morning..seemed like a dead battery..so I hooked up a charger..after charging overnight..I tried it and nothing..just a humming noise from the bottom of the car when turning key to start position..starter will not engage..noise continues until key turned off..after a day of charging and having same issues.. I called Midas to diagnose and fix problem..towed to Midas..I had called my symptoms in to Midas..when mini got there, it started right up..I went to get it..drove it 20 miles..played golf..same no crank with humming noise..towed back to Midas..I rode with tow truck and when he unloaded ..it started right up..I drove it home..stopped to get gas..again no crank with noise..towed back..they have had it for 3 days..changed the starter..same problem..checked all the relays,, fuses..I know there are only so many things to disable the starter..clutch switch, ECM, IBS, ignition switch..battery cable..got any ideas?? we are stumped
mini cooper s 04 riding real rough.. every bump is a teeth chattering experience..I checked tire pressure and its ok..could a real rough ride be just worn out suspension ?? feels like solid suspension..no cushion at all.thanks for any help from anyone here..
Hello Bunzee, just saw this, did you get the problems at Midas sorted out. On the suspension I bet the struts are shot and possibly a spring might be cracked, can you post up pics and has it always been like that? How many miles do you have?
04 Mini Cooper S
yes..midas figured it out..the friggin battery to the KEY was going dead..everytime I had it towed, I gave them my spare key (chip only) and it stated right up every time for them..and when i got it home I switched back to the push button kind of key,and no crank ..I have 119K on the mini..bought this car 4 months ago..I am pretty much going thru everything. trying to create a history for this car...replaced coil..spark plugs and wires..brakes, front, rear..tires, just got it back from paint.(.peeling clear coat)..new tail lights..headlights..thermostat and housing replaced..I have both front axles purchased..not installed.probably water pump in the future..car runs real well but...pouring alot of money into a car I will never get a return on..but it's fun to drive and I want a dependable, safe car..
2008
Changed the battery and now it won’t start. The key fob works the locks. I checked all the fuses under the dash and they’re all good. Battery has full charge. Put the key in and nothing
Originally Posted by Smelly
(Post 26777)
Originally Posted by bunzzee
(Post 26778)
do you have a key without the battery??that was my problem..as soon as I started using a key with chip only..never had another problem.I was told from the Mini dealership FOB key was bad..$275 for new FOB key...screw that..I just use my non battery key now..never another problem..
(Post 26779)
It’s the round fob with the removable key.
lamp mode Mini Cooper 2010
Hi good day , my mini put limp mode because of a damaged ignition coil , I replace it and since the car is in limp mode , I changed also the 4 spark plugs but still any idea?
best regards |
| All times are GMT -5. The time now is 05:56 AM. |
