Engine management light
Hi members, I have just bought my first Mini Cooper a month ago, love it!... But 2 days later EML came on. I had it diagnosed locally to me and said it was oxygen sensors. So it went back to dealer as it has 6 months warranty they said they would sort it. They put 2 sensors on, one each side of the CAT. Had it back nearly 2 weeks and light has come on again. I'm a tad fed up as I don't live near where I bought it from, it's about an hours drive and is costing me in fuel and train fares. Any ideas what else it could be?
You'll need to plug into the OBDII port and check for faults. A P code should be present, which will lead you to an idea of what the issue is. If you don't have a diagnostic scan tool, sometimes a local Autozone should be able to read the code. What symptoms does your MINI exhibit?
You might have an intermittent issue at foot, but you'll still want to pull the stored code to figure out what is causing your issue. Even though the light has turned off, the code will still be present in the system.
Aug 21, 2015 03:00 PM
Aug 21, 2015 02:49 PM
Michael Lytle
May 26, 2014 07:08 AM
hgiljr
Jun 30, 2007 07:13 AM
