air pressure sensor removal
Old Jan 21, 2013 | 06:20 PM
berserker10's Avatar
Default air pressure sensor removal
if I mount new tires without the air pressure sensor will I receive signals that I have flat tires?
Old Jan 21, 2013 | 07:07 PM
yes if you are putting on different rims/tires without the tpms sensors
if you are mounting tires on the stock rims with the sensors you'll have to reset them
and you should NEVER mount runflats without tpms sensors
Old Jan 21, 2013 | 11:46 PM
Hawkfan72487's Avatar
Member
i've got an 06 cooper S. i thought that the pressure sensor was actually just a sensor monitoring the rotation of the four tires not the actual pressure, thus if a tire was low, its diameter would be smaller making it turn faster in order to travel the same distance as the other tires. Am i wrong on this? If i am correct and all that it's doing is monitoring the rotation then i'd be safe to put my other wheels on wouldnt i? i have a set of 17" konig verdict wheels with winter tires on them from my 03 sentra that i used to have.
Old Jan 22, 2013 | 05:49 AM
Is it safe to mount 17x 7 rims with a +45 offset on my 2010,clubman S?
Old Jan 22, 2013 | 04:25 PM
first gens do not have tpms in the wheels ...
second gens run wheel sensors ...
yes ou might be able to run the sentra wheel I'm not sure of bolt pattern/offset
and I believe I answered YES I'm running 17X7's 45 offsetobbie
Old Jan 23, 2013 | 06:54 AM
Thanks! Just wanted to make a rim application double check! Thanks again I will order my new rims directly!
Old Jan 24, 2013 | 02:28 PM
Member
my sentra had a 4x114.3 bolt pattern but the wheels im referring to are a universal 4bolt pattern i believe.
they were white but i painted them a charcoal grey
Old Jan 24, 2013 | 03:49 PM
  #8
As long as the other pattern is 4X100 and correct center bore and offset
terencekent
Jan 19, 2018 06:27 PM
berserker10
Feb 8, 2013 08:40 AM
Justlooking
Jun 27, 2011 12:17 AM
nan2cool
Oct 12, 2010 10:58 AM
