Blown head gasket or more serious damage?
Old Mar 4, 2023 | 10:16 AM
rjh914's Avatar
Default Blown head gasket or more serious damage?
My 2009 Mini overheated in traffic and shut down on me. I was able to get it restarted and drive it to a parking lot.
I've now got milky oil and white smoke coming out of the exhaust. I drained the oil, left the drain plug out and added coolant to the reservoir...it ran straight through the engine and out the oil drain hole.
I'm new to Mini's. Is there anything that could be causing this aside from a blown head gasket, cracked head or cracked block?
When these engines overheat badly are they typically worth trying to rebuild, or are the heads and block prone to cracking?
Thank you.
Old Jun 16, 2023 | 08:20 AM
Jack's Avatar
Hi mate, sounds like a head gasket issue. It could be a hole in the block but I highly doubt it.
Let me know how you got/get on
Ricky72
Apr 9, 2022 05:02 PM
Nacho2to
Oct 6, 2021 11:36 PM
John M. Snyder
May 20, 2017 01:34 PM
mlg321
Jul 24, 2011 04:00 PM
targhee
Oct 11, 2007 12:01 AM
