Got the dreaded yellow half-engine warning, limp mode, and codes ahoy
Old Jul 7, 2020 | 09:36 PM
stokestack's Avatar
Default Got the dreaded yellow half-engine warning, limp mode, and codes ahoy
Hi all. Got a 2013 Clubman here with about 70,000 miles. On the highway it started shuddering, displayed the half-yellow check-engine light, and would barely move.
Subsequent code check revealed P0300 and P0300 P. I've replaced the battery, spark plugs, and coils to no avail. I checked the fuel-rail pressure and it reads 60 PSI with a dial-type tire-pressure gauge (not the optimal tool, I realize); from that I conclude that it's probably not the fuel filter or fuel pump, although the filter is probably due for replacement.
Now a code check pulls all of these:
p0300 multiple cylinder misfire
p0302 cylinder #2 misfire
c0300 rear speed sensor malfunction
c0700 something MAF-related? Hard to find good reference on this
p0597 Thermostat Heater Control Circuit Open
I find it suspicious that all of these things are suddenly occurring at once; can an electrical disturbance cause spurious codes?
I don't know what to try next. Advice appreciated!
califresh119
Mar 19, 2025 12:50 AM
KusoBabA
Nov 13, 2019 06:11 PM
StanP50
Sep 18, 2019 07:33 AM
EMPIR3
Jul 22, 2019 10:46 AM
colonelangus
May 19, 2019 10:27 AM
