07 Cooper S 1.6L Turbo
Old Sep 28, 2024 | 08:53 PM
07minicoopers's Avatar
Default 07 Cooper S 1.6L Turbo
Hello MINI Friends, need you input
Mini was running great got a check engine light after filling up with junk gas not sure if that has anything to do with the issue . shut the car off for the day went to start next morning and it started but was running rough pushed the gas pedal and no response, shut the car off restrated with partial throttle and revved to 3k runs fine, but now each time i go to start same thing rough as hell shut down partial throttle and it clears up the check engine light went out and it has no fault codes? bit puzzled i know the TPS is in the Throttle body maybe that? Gas pedal sensor? it has a New Vanos valve changed 500 miles ago with the Timing chain kit?
Darrell
k9182
Nov 8, 2022 02:08 AM
Nic900
Jan 7, 2020 08:15 AM
bengoolsby50
Sep 4, 2018 10:01 AM
cdrake7266
12
May 16, 2018 02:50 PM
Derek
Nov 20, 2015 12:35 PM
