Gen 2 Leaking Oil / Told this is normal
Old Aug 27, 2015 | 02:23 PM
Dave2009S's Avatar
Default Gen 2 Leaking Oil / Told this is normal
Local Mini repair shop says Generation 2 Minis all leak oil. Says this was fixed in generation 3. Do Gen 2 cars normally leak? My 2009 S has three oil sources and an estimate of $1600 to fix.
Old Aug 28, 2015 | 11:22 AM
PelicanParts.com's Avatar
The first and second gen MINI's do have some known oil leaks. A common one with the R56 is the timing chain tensioner as it has been known to not have been properly torqued at the factory. Also, known leaks can come from the crankshaft seal and/or valve cover. Did they tell you where the leaks are coming from?
Old Apr 11, 2016 | 07:04 PM
texasbaehr's Avatar
My 2007 S had a small leak around the cam cover. That was an easy fix with a new gasket kit. Took about an hour to replace. Other than that I have no leaks at 114K Mi.
Old Apr 26, 2016 | 10:54 AM
mini007's Avatar
My Turbo oil supply line is leaking a bit, not sure if this is a big deal...
michmike
Dec 4, 2014 12:06 PM
Nisha 1
Dec 4, 2009 11:39 AM
Idaho Mini
May 27, 2009 09:44 PM
benito
Jan 22, 2009 11:27 AM
spurite
Jan 15, 2009 04:37 PM
