TPMS goes Inactive for no reason
Old Jan 22, 2018 | 07:13 AM
MSgtEgress's Avatar
Default TPMS goes Inactive for no reason
I have a 2008 S with 57K mi. Has anyone ever had their TPMS continually go inactive for no reason? It started about a week ago. I checked all the tire pressures (all good) reset the TPMS and it went away for about 4 days, then I was driving and it pops on again. Re-check the tires again reset and it comes back 2 days later. Then wouldn't reset, I shut off the car for 30 min and I go out and start it, light is out. Now its happening almost every day. Do I have a bad sensor some were?
Thank you all for your help
Old Jan 29, 2018 | 07:32 AM
richjones24's Avatar
I'm having the same issue, just had new wheels and tires installed. After resetting the Inactive reappears?
Old Jan 29, 2018 | 01:39 PM
MSgtEgress's Avatar
Yes I reset and it goes inactive after 10-20 mile. Now it mysteriously resets itself and works for awhile then goes inactive suspect one tire sensor is flaky and is intermittent. I am buying a set of rims and tires from a 2011 convertible with good sensors. I’m going to swap them out to confirm it’s a sensor
Old Feb 3, 2018 | 01:28 PM
MSgtEgress's Avatar
Well the used rims I bought must have multiple bad sensors because the TPMS wont reset at all. I bought them for snow tires next year anyway. I've come t the conclusion I have at least one bad sensor.
Old Mar 4, 2018 | 03:30 PM
Big_AL_in_JaxFL's Avatar
It is my understanding the batteries in the TPMS wheel units go bad after about 5 years. There is no way to tell how long the sensors sat on a shelf before installed on your rim and you will be shocked to know.... the batteries are NOT replaceable. I hope that helps in some small way.
AL
Old Oct 24, 2019 | 08:22 PM
Roger1244's Avatar
Default 09 minicooper convertible R57
I changed the sensor that was bad but still i'm unable to reset it, it just shows INACTIVE , i had the tire shop check all the sensors and 1 was bad, they replace it, now they did test them with their computer but still im unable to reset the TPMS alert. any suggestions?
Old Jun 12, 2020 | 02:23 PM
nhatdallas's Avatar
Hi have you solved the problem of the message Inactive. I have same since i've changed the 4 wheels.
Thank you.
Old May 7, 2021 | 08:07 AM
  #8
Matthew Moore's Avatar
Hi did you ever get your wheels working? I am having the same problem on my 09 S, works and goes inactive, seems to be getting worse, I was able to reset everyday, but now some times it won't even reset I have replaced all 4 sensors with no luck. I have a bmw scan tool and the only code coming up os for the RDC module. I am hesitant to invest in a new module.
MSgtEgress
Jan 23, 2018 10:36 AM
terencekent
Jan 19, 2018 06:27 PM
berserker10
Jan 24, 2013 03:49 PM
surfndude44
Jul 4, 2011 05:35 PM
pcowle
Mar 14, 2009 01:49 PM
