Doors refusing to lock
Old Jul 7, 2022 | 05:54 AM
Keishamitch's Avatar
Default Doors refusing to lock
Hi, im a new owner of a 2nd hand mini cooper 2002 R50 model. Just today my car has refused to lock. I've tried using the key fob to lock it but when I press the button it locks and unlocks straight away....I've tried inserting the key into the door to lock also but the car tried to fight it, I can only lock the doors if I hold the key in place in the door until the mechanism stops fighting it. If anyone knows how to fix this can you please let me know ASAP, thank you
Old Aug 27, 2022 | 01:42 PM
BREEZ's Avatar
Default Same issue, 2003 mini door won’t lock
I am having the same issue. I just bought it from a private party with the need for a new transmission. The doors will not stay locked.
Old Aug 27, 2022 | 08:20 PM
Definitely check the battery, I had my whole car serviced and it still had the issue on and off, the battery needed to be changed as it had turned black and constantly needed charging or it would die - with that came a lot of electrical problems, my lights wouldn't work, or my dashboard lights wouldn't turn off even without the key in the ignition. It's been 3 weeks now with the new battery and so far everything is in working order (knock on wood). It could be many things, but I suggest looking at the battery as it may be on its way out, thus causing the electrical issues
Old Jul 22, 2023 | 04:59 PM
mini_newbie's Avatar
Default Samesies
Exact same thing is happening to me. Has anyone else figured this out or had luck with replacing the battery?
dima1616
Jul 21, 2023 06:16 PM
Mercinary
Jul 12, 2017 08:18 AM
ssoliman
Dec 28, 2014 06:35 AM
Spyder7892
Jan 22, 2011 02:04 PM
skinner9
Nov 27, 2010 07:12 PM
