tell me your mini issues
Old Mar 19, 2016 | 10:34 PM
  #111
Laurieand Brian Troxal's Avatar
I took the motor and trainny out of my 2008 mini cooper base 1.6L and changed my chains and belts and put motor and trainny back in. turned over slowly to start with so I figured it was the battery so I bought a new batter now it wont turn over at all. lights come on and i can hear the relay and solenoid kicking in but its not turning over at all. checked all my grounds and they are all good. so could someone please help me on what could be the problem.
Old Mar 21, 2016 | 11:07 AM
  #112
PelicanParts.com's Avatar
Check the connections at the battery. If they're loose, it'll cause a no start. Also, do you hear the fuel pump prime? Is it cranking?
Old May 2, 2016 | 01:56 PM
  #113
bchgrl's Avatar
My battery died. I jumped it...battery is fine. Now the headlights, blinkers, power windows, and dome lights don't work. No codes are read by OBD. What could the problem be?
Old May 6, 2016 | 08:47 PM
  #114
Sonnyalimusic's Avatar
I have a 2014 cooper. The mirrors on my sun visor won't stay up. I have to hold them open to look in the mirror. This is on driver and passenger side.
- how can I turn the fog lights on and off? Are they just automatic?
Old May 9, 2016 | 10:40 AM
  #115
How old is the battery? Did you test the voltage?
Old Jun 21, 2016 | 05:45 AM
  #116
HANKFROMTHEBANK's Avatar
44000 miles on 2013 Mini Roadster....Mini warranty expires in a few months ..should I pay for extended warranty or do the scheduled maintenance and hope for the best as my mechanic recommends ??
Old Jun 22, 2016 | 01:32 PM
  #117
Mandinca's Avatar
I've found a Mini Cooper S 2007 turbo for sale with a seized motor. I'm tempted because the price is right but I'm unsure which engine to get as a replacement. I want to be sure it's compatible and see many for sale on ebay, car-parts.com etc but the prices vary wildly.
They seem to be either under $1000 or over $3000.
Can you offer any advice ?
Old Aug 17, 2016 | 05:07 PM
  #118
R53hoonigan's Avatar
Default Exhaust issues
Hi, I just recently installed headers and an invidious racing exhaust on my r53 supercharged mini, and since then it has sounded amazing and everything, but between about 2 and 4 thousand rpms, the car jumps back and forth when I'm on the gas, I'm not sure what's causing it but I have read it could be an o2 sensor, which I believe mine is bad as it is throwing a code for it. Any ideas would be amazing, just replaced the plugs and changed oil as well so it isn't that
Old Oct 31, 2016 | 11:39 PM
  #119
Wardgomez's Avatar
Hi there! I was running only 50km last night suddenly the idle went up and transmission won't shift (automatic transmission) appreciate your commitments. Cheers!
Old Nov 27, 2016 | 11:42 AM
  #120
rayne's Avatar
I have a 2007 Mini S. Yesterday the parking lights would not shut off after keys were removed. Didn't drive the car yesterday but noticed later in the afternoon they were on. Now the locks wont even open. Anyone out there have this same problem, how did it end?
