2009 S Oil Pump Chain
Old May 9, 2018 | 05:38 PM
The Postman's Avatar
Default 2009 S Oil Pump Chain
I recently replaced the timing gear in the car and about 3 weeks after I did the work I started getting a rattling sound from the timing chain side of the motor. I took the valve pan cover off and everything looked normal. I then took the oil pan off and removed the oil pump cover and noticed the the oil pump chain appeared to have a lot of slack. I took a video of it and was looking for opinions on it. Here is the Youtube link to it. Thanks !
Old May 15, 2018 | 12:45 PM
Minitobe's Avatar
Member
the oil pump doesnt exert tension on the crankshaft. this is normal play for the chain and the cover actually puts some tension on it.
did you do the whole timing chain kit or what was it? the original chain might be stretched!
munky
Feb 8, 2017 11:54 AM
bcdeluxe
Nov 30, 2016 10:47 AM
michmike
Dec 4, 2014 12:06 PM
Tiffiee
Mar 4, 2012 07:59 AM
AnneDarling
Nov 17, 2010 10:52 PM
